Unless the Y33 is different, I believe you only need (4) bearings. 1 for the water pump/PS, 1 for the AC, and (2) for the alternator. So if you can get them for $9.50 each (from McMaster per above), that's $38 + a little for shipping. I can't imagine someone charging $30-$50 EACH, should be like $30-$50 for all 3 of them. So, that's $90 for all of them.paranoidjack wrote:Also Wes, that math doesn't seem quite right -
The bearings (for nice sealed ones) will be $12-$15 each, at least the best I've found, and needing 6 of them that's $90-$100. If you don't have a press, you'll be paying another $30-$50 to press them in, and who knows if the guy did it without compromising the bearings? I have nightmares because I tried to replace the bearings in my washing machine instead of the entire spindle ($45 instead of $350) and it lasted 3 months.
So if you add that all up, it's not SO Bad to just get the bearings at ~$240 with all new tensioning hardware, versus $150 for just the bearings pressed in?
If you have the right bearings at the right price and a press it makes sense to go that route, but if you don't have that stuff and it's your only driving (or non-driving) vehicle, pulleys might be your best option.
Either way, your last statement is right on...
