here is a link to the car i bought.
http://www.pistonheads.com/classifieds/ ... ce/4183388
ANY info about some of the mods would be appreciated... this is what i really have questions about;
pros and cons of the MAF delete kit
how do i figure out what cams it has?
has HKS adjustable actuators... what do i do with them(i dont want to mess with them)
how do i figure out what size my injectors are?
NISMO oil seperator - whats the purpose of this?
what in the world is a Arc water cooler system? looks like it has some plumbing running around the engine for it.
once i get it, all the fluids are getting changed. i also want to add an oil filter relocation kit to it for ease of changing the oil filter. yes, the car does have a BGW on it but i honestly did not care as a couple hundred in body work to remove/replace if i desire was well worth the mods this car has.
it has HKS 2530 turbos. what wheel horsepower should this car be good for? what is the max boost you should run on a stock engine(assuming stock because nothing was said otherwise). i dont want to dial it up as i dont really understand the car well enough having never dealt with them. thanks
