Mark Booth »
https://forums.nicoclub.com/mark-booth-u77813.html
Fri Aug 07, 2009 7:24 am
I change the oil in my EX35 and find it quite an easy process. Here are a few "tips" that might help others with the oil change...
First off... The oil sump on the EX35 runs perpendicular to the motor. Meaning, the sump runs east/west while the motor and transmission run north/south. Also, the sump is located near the very front of the engine (completely hidden under the bottom pan). Because of the location of the sump, the EX35 must be level when you drain the oil (or be slightly pointed downhill -- nose slightly lower than the tail). This means you can't drive the EX35's front wheels up onto ramps on level ground to drain the oil. The rear of the engine could end up being lower than sump and, thus, you might not drain all of the old oil.
Frankly, the EX35 sits off the ground enough that it is possible to squeeze under the car enough to change the oil without jacking it up. But I prefer more room to maneuver so here's my procedure:
1) I back the EX35 into my garage. I then pull forward just to the point that I can open the driver's front door without hitting the side of the garage opening. This positions the front wheels in the driveway and the rear wheels in the garage. I then place my ramps (Rhino Ramps) in front of the front wheels and then drive the EX35 up onto the ramps. The result is my EX35 is positioned so the rear wheels are just at the spot where the slopped driveway meets the level garage floor and the front wheels are on the ramps. Since my driveway slopes downhill away from my garage, the top of the ramps are just a tad bit lower than the level spot where the rear wheels are positioned. The EX35 is then almost level, with a very slight tilt downhill at the nose. PERFECT for changing the oil. And, thanks to the ramps AND the downhill slope of the driveway, I have PLENTY of room to get under the front of the car. In fact, there's almost too much room because the used oil has a bit of distance to free-fall.
2) I open the hood and remove the oil filler cap.
3) Move to under the car and use a 10mm socket on my battery-powered electric drill/driver motor to remove the bolts around the circumference of the bottom splash pan. (NOTE: The four bolts along the BACK of the splash pan are slightly different than the rest of the bolts around the circumference... be careful to put those four back in the right spot when reinstalling the pan.) At this point, the splash pan is still held in place by three push-pin type of fasteners across the center of the pan. Using a slot screwdriver, gently pry out the center pin of the left and right push-pin fasteners and pull the fasteners from their holes. Now you'll have a splash pan that is perfectly balanced in place by a single push-pin fastener. Gently remove the middle push-pin fastener and remove the splash pan from under the car.
NOTE: With a battery drill/screwdriver, removal of the splash pan takes less than 2 minutes! It's a piece of cake!! And Infiniti's use of the push-pin fasteners across the middle makes it VERY easy to remove and reinstall the pan! Excellent!
4) The rest is standard procedure... Place a oil drain pan under the sump (the east/west black pan with the bolt in the end of it that faces the front passenger-side wheel), remove the drain plug bolt, and drain the oil. You'll see the oil filter is VERY easy to access. On the RWD models, it's directly above the oil drain plug. A mere few inches above! Very convenient! You don't even have to move the oil drain pan to catch the oil draining from the oil filter. (Be careful, the oil has a tendency to spray out of the filter bottom fairly quickly as you loosen the filter.) If you have an AWD model, the oil filter isn't the same side as the drain plug. Rather, it is on the front of the engine pointing toward the radiator. But it is still located nice and close to the bottom of the engine near the sump. Once all the oil is drained, clean up the area around the filter with a shop rag, including carefully wiping the surface where the oil filter mounts. Lubricate the O-ring on the new filter with some fresh oil (yes, this step is VERY important as it prevents the O-ring from binding and possibly breaking when installing the filter) and screw the new filter in place. Tighten it HAND TIGHT. Meaning, as tight as you can get it with your bare hand as long as it is at least 3/4 of a turn from the spot the filter O-ring first contacts the base but not more than 1 full turn. Reinstall the drain plug bolt, being sure the copper drain plug washer is in good shape (I replace my drain plug washer with every 2nd or 3rd oil change). Tighten to the torque specification indicated in the owner's manual (I forget what that spec is so be sure to look it up!). Then, move topside to put in the new oil. The oil capacity of my 2008 EX35 Journey is 5-1/8 US quarts. So, I start off by putting in about 4.75 quarts, reinstall the oil filler cap, and start the engine and let it idle for 2-3 minutes. While it is idling, I check for leaks around the oil filter and drain plug (be careful under the car when the motor is running!!!!!!!). Then I shut off the motor and move back under the car to reinstall the splash pan....
5) Position the splash pan in place under the car and reinstall the very center push-pin fastener! VOILA! A perfectly balanced pan that you don't have to hold up while you are trying to install the bolts and other push-pin fasteners! VERY clever design by Infiniti!! I set my battery drill/driver to the screw drive position and set the torque clutch so just driving right up until the driver clutch skips is a couple of foot pounds to hold them in place. I've never had one fall out and, again, you can reinstall the pan in mere minutes.
6) After checking that everything is out from under the car, I carefully back the EX35 off of the ramps into the garage so all four wheels are on a level surface. After the EX35 has sat with the motor off for about 5-10 minutes, I pull the oil dipstick, wipe clean, reinsert and check the oil level. With every change so far, I've had to add the last of that 5th quart of oil (making 5 quarts total). This brings the level on the dipstick up to just a little bit below the hole in the dipstick below the full mark. I could put in another eighth of a quart but I never bother to. The car doesn't burn enough oil between 3,000 mile changes to even register the difference on the dipstick.
The long description above might make it seem like the oil change on the EX35 is difficult. It isn't! In fact, I've owned MANY cars that were far far more difficult. Don't let that splash pan removal slow you down! It is incredibly easy and quick to remove the splash pan with a battery-operated drill/driver! And, best of all, once the splash pan is removed, the drain plug and filter are "right there", conveniently located for easy removal!
Lastly, I use regular dino oil in all of my cars! I experimented with synthetic oil (Mobile 1) in a couple of my cars and they both started having minor oil seeps around the gaskets once I'd been running synthetic for awhile. Switching back to dinosaur oil eliminated the seeps. And, if you change every 3,000 miles, the dino oil offers PLENTY of protection.
Mark
P.S. My thanks to my friend Tom for the recommendation on placing the ramps in the driveway so the car will remain level.
Modified by Mark Booth at 10:37 AM 8/7/2009
