Exactly, just remove the belt, turn the cam and crank sprockets, and reinstall the belt as I mentioned. Soon as you have the covers off, rotate it until the white lines "should" line up and see if it is truly off. If it is, once it's reinstalled I'd do a leak down and compression test to confirm if there are any bent valves.robomatic12 wrote:aslong as all of the dots are lined up on the timing belt and the dots on the cam gears you are fine, doesnt matter where in the compression cycle its at, all that matters is the dots lining up. pull your belt covers and check everything without taking the timing belt off.
so i took the covers off of the timing belt and the dots still are lined up. i also ran a quick compression test and i am not getting anything. I dont think that my valves are bent however because that is what started this whole mess. (timing belt slipped and i actually broke 4 off, $500 later at the machine shop, i was very careful putting the heads on) I am just wondering again if in fact i did set it to the exhaust stroke instead of the compression stroke if for some reason i might have the wrong valves open? the reason why i think that is because going back and reading through the manual agian it says to make sure that i am on the compression stroke. what do you think? also i can rotate the crank by hand and turn the crank one full turn and the cams are then off. rotate it again and they are lined up again.Zwicked wrote:
