Postby
AlexN09 »
https://forums.nicoclub.com/alexn09-u185794.htmlWed Feb 13, 2013 12:42 am
Oh I gotcha, I have mine sitting on the dash right in the corner... But I am installing tweeters in the dash location under the grills and am going to be making a mount for the GPS antenna because I hate having it up and visible. Ill make sure I post a picture for you by this weekend!
Postby
AlexN09 »
https://forums.nicoclub.com/alexn09-u185794.htmlSun Feb 17, 2013 9:39 pm
Mine fit under the dash grill like this:
Just to clarify, I simply set the antenna on the spot where the auto headlight light sensor is on the other side. So on the passenger side you should have an auto light sensor and on the driver side is your antenna. Mine happened to fit snuggly under the grill and still leave room for my tweeter bracket and tweeter without obstructing the sound.
Postby
AlexN09 »
https://forums.nicoclub.com/alexn09-u185794.htmlTue Feb 19, 2013 5:24 am
You need to pull from the top of the a-pillar down towards you to remove it. Be careful because there's an airbag there lol. Than you can pull up on the grill.
