meet07 wrote:So what happens if you dont turn down the dwell??? Im assuming you get to much spark but what are the side effects??
240z4u wrote:What do you mean by turn down the dwell? It is going to get turned up!
Yup, 240z4u has it right. The LSx coils are pretty big and strong and work best with a lot of dwell. So if you don't have a way to increase the dwell versus the stock dwell then they aren't running near their full potential.
BTW there was some question as to the strength of the spark, and what I will say is that I had working R33 RB26 coils before and had to have my gap down to like .020-.025 on 18psi to guarantee no spark blow out. Once I did my conversion to LS2 coils I was curious to see so I actually put in my plugs at .040 gap and still never had any blowout at 22psi that I ran all last year... Hell I don't even have the dwell all the way up and I didn't even change the plugs for a full year and didn't get any blow out until I experienced some minor blowout this year when I turned it up to 24psi on an E85 mix! All I did was put in new plugs and left the .35 gap they came with and good as new... So they are WAY stronger than the stockers/splitfires.
The LS2s are stronger than the LS1s so I am not sure how they will hold up, but I would guess even the LS1s are also stronger than the stock stuff by a considerable margin.
As for gas mileage... I'll be honest I didn't see anything measureable... As for power the car felt smoother and maybe a *little* more powerful, but I never did any before/after dynoing so I am not sure. Nothing more than a "butt dyno". I did it primarily to ensure that I could turn up the boost without worries of spark blowout and having to run crazy low gap.
Modified by WhatsADSM at 10:45 PM 7/6/2009
