leadpawhttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=34157ec346090313840ae767bac71453An ambitious projectSun Feb 20, 2011 11:32 am
Postby
leadpaw »
https://forums.nicoclub.com/leadpaw-u149518.htmlSun Feb 20, 2011 11:32 am
Through some research ive found that my 85 sentra Diesel b11 shares an almost identical block to the Ca engines, both being C series engines. My diesel engine gave up because of a bad oil pump so i decided to try to put a U12 ca18de in it.
CD17 diesel vs CA18det
Helpful critique n stuff welcome.
Postby
themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.htmlMon Feb 21, 2011 7:54 am
Stroke's right, bore's wrong. The cylinder spacing is the same but the idea of punching the cylinders up 3mm gives me pause. The head bolts are likely an M12 which requires machining the head to clear the RB26DETT head bolts. The SOHC timing belt has the tensioner in the wrong position, but if you.... Perhaps I have said too much.
Postby
float_6969 »
https://forums.nicoclub.com/float-6969-u780.htmlMon Feb 21, 2011 1:51 pm
I already checked Mike. I knew it wasn't what you were looking for.
Stock CA18DE fuel pressure is approx 37psi with the engine off and the fuel pump running. I have a writeup in the FAQ on how to set your fuel pressure the right way.
Volume can be pretty small. The DE doesn't make a crazy amount of power.
Postby
themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.htmlSat Aug 13, 2011 11:03 pm
Why, ain't nothing wrong with using a battery with some nuts. I hate listening to the cheap guys jump into their race car and hear the low-cost tiny battery they bought try to spin their engine.
Postby
leadpaw »
https://forums.nicoclub.com/leadpaw-u149518.htmlThu Dec 29, 2016 11:08 pm
well 5 years later the ca18de did many trackdays and autox events and covered more than 90k miles. Then I thought time to turn it up a bit.
out she came.
Postby
Izento »
https://forums.nicoclub.com/izento-u122144.htmlSat Dec 31, 2016 9:13 pm
How do you like the turbo life? Have you had to change your driving style significantly to accommodate the power curve of your new powerplant? I've never driven anything hard other than turbo cars, so I couldn't comment on an experience like that.
Postby
leadpaw »
https://forums.nicoclub.com/leadpaw-u149518.htmlFri Jan 06, 2017 8:12 pm
Yeah its a totally different experience. Torque steer is pretty pronounced now so I have to prepare for that during corner exit. Furthermore I now have a T25G on it that spools slightly later, so I have to also plan for that or end up unsettling the car when the turbo picks up. Its alot easier to control lift throttle oversteer now which B11 sentras are bad for, you just basically floor it and it smashes the rear wheels into the ground to regain grip. Overall yes the driving strategy from DE to DET is very different. From just pinning it all the time to threading a needle.
