IIRC the Reference series handle roughly 100 watts RMS and 80 RMS respectively. You'd want something that can do around 400 watts RMS @ 4ohms, so 100 per channel. It doesn't HAVE to be 100 per channel but that would be your ideal goal.kencyr1 wrote:I'm installing 4 infinity reference door speakers in my 2011 rogue, and am wondering which amp to install. 2 are 180 watt, and 2 are 300 watt. I plan on installing a separate amp and sub later on. Basically I'm wondering what amp would be suitable for the door speakers? I am also putting in a pioneer dvd head unit.
rdub2k4 is one of our resident "audio go-to guys". he's one to chat with.rdub2k4 wrote:IIRC the Reference series handle roughly 100 watts RMS and 80 RMS respectively. You'd want something that can do around 400 watts RMS @ 4ohms, so 100 per channel. It doesn't HAVE to be 100 per channel but that would be your ideal goal.
I like the MB Quart 4 channels, cheap clean power. My friend is running this gem in his WRX.
http://www.sonicelectronix.com/item_241 ... X4.80.html
It looks and sounds good, 80watts per channel @ 4 ohms.
You're looking when the new 2013 models are coming out though, so some of the prices will vary. This is the 2013 4x100 MB Quart, no pic yet.
http://www.sonicelectronix.com/item_678 ... 800.4.html
I'm gonna assume the +3db is on a crossover for components? If it is then it's not really a bass boost, but a way to equalize volume between tweeter and woofer. If that's not where the +3db is at then ignore this statementkencyr1 wrote:Any advice on whether to leave the bass boost on or off to the infinity speakers? Has a little button on them that says +3dB
right on!rdub2k4 wrote:Personally, I don't run bass boost on Amps period. Most of the time the amps distort the signal "boosting" the bass and you end up clipping speakers. This usually leads to muddy/distorted sound and shorter speaker life.
Also, the center where the button is, is positioned at an angle, so you can direct the sound either up or down, depending on how it's installed. I'm assuming I should aim them up?kencyr1 wrote:The button is directly on the non-component speaker. Right in the center of the speaker. I agree I like my sound more clean and crisp, and I plan on adding a w7 or 2 in the future. Fyi, I bought a 1200 watt pioneer amp, rated at 500 rms I think.
Any chance can you post a model # of the speaker? I want to look it up so I can give you more accurate advicekencyr1 wrote:Also, the center where the button is, is positioned at an angle, so you can direct the sound either up or down, depending on how it's installed. I'm assuming I should aim them up?kencyr1 wrote:The button is directly on the non-component speaker. Right in the center of the speaker. I agree I like my sound more clean and crisp, and I plan on adding a w7 or 2 in the future. Fyi, I bought a 1200 watt pioneer amp, rated at 500 rms I think.
yessirImStricken wrote:right on!rdub2k4 wrote:Personally, I don't run bass boost on Amps period. Most of the time the amps distort the signal "boosting" the bass and you end up clipping speakers. This usually leads to muddy/distorted sound and shorter speaker life.
http://www.pioneerelectronics.com/PUSA/ ... s/GM-D8604rdub2k4 wrote:Nevermind I looked it up. I'm assuming this.
http://www.sonicelectronix.com/item_189 ... 632cf.html
It's a tweeter level adjuster. If you install the speaker and you feel your highs are not as balanced as they should be, you can flip the switch to add +3db's of power to the tweeter. Being behind a door panel/grill, it might be a good idea to turn it on, but it's all personal preference.
Tweeters should be facing towards the passengers. If the 6x9 is mounted at diagonally like the door shape, point the tweeter towards the driver to get the best sound.
Pioneer makes good amps. Post up that model # too so I can check it out
Ok cool thanks for the info. Can you suggest a wire size for the app?rdub2k4 wrote:Those aren't bad at all. Nice pickup.
But as far as the +3db goes, u might have to install it first to decide if u want the +3db or not.
rdub2k4 wrote:Well the amp itself takes a 4gauge power/ground wire. You said you were planning on running a separate amp for the subwoofer, so you might want to look into a 1/0 dual amp kit, or a 2 gauge amp kit. I like running Knukonceptz wires as they're cheap and flexible.
http://www.knukonceptz.com/productDetai ... D=KFX-PK20
It just needs speaker wire and RCA cables.
4 channel RCA's
http://www.knukonceptz.com/productDetai ... =KARSS4.6M
Subwoofer RCA's
http://www.knukonceptz.com/productDetai ... =KARSS2.6M
4 channel speed wire for hooking up door speakers + amp remote turn on (Run wires from the amp back up to your headunit area. Connect to aftermarket harness, color match. Tape away speaker wire coming from deck).
http://www.sonicelectronix.com/item_241 ... osche.html
