Anything I should add before I finalize and ship everything?
Added bypass hoses. I'll get plugs as well. Ordering from IPP. They're by far the best price around.BigTDogg (MA) wrote:Yes, add silicone bypass hoses. They're cheaper than OEM and last forever. Might want to get plugs while you're in there.
Where are you ordering from?
TB and IACV gaskets. Good idea as well. Probably not a bad idea to clean them.nissanfreak12 wrote:Plug for the exhaust when you delete the EGRCan't just use a bolt? The other kit is twice the price...
Knock sensor and wire for knock sensor-good measure since your pretty much thereOoof, there's another $200....
Extra fuel line-sometimes you have to cut the hose when removing Auto parts store
Plenum gasketAdded. Completely forgot.
Are you just putting the bar for the hicas delete or eliminating the whole system? I'll eventually swap the pump and reservoir over, but for now, I'm just gonna do the bypass and remove the rear actuator and the rear lines.
How are the injectors? I'm not gonna jinx them, lmao.
Are you doing the water line delete under the plenum? Most likely.
I believe a bolt will do just fine, just get a tiny one, length wise and seal it with a copper o-ring.Ace2cool wrote:IIRC, The EGR has a tube that goes to the exhaust, then runs to the actual EGR "spaceship-looking thing" on the back of the engine, then two tubes that run to the bottom of the plenum, which is what the blockoff plates are for, am I right? I was saying a bolt that fits the exhaust threading, to block off the hole from removing the tube.
And thanks for the tip, just ordered the relocate kit from Bernie. Good stuff.
Bernie also sells the egr exhaust plugAce2cool wrote:IIRC, The EGR has a tube that goes to the exhaust, then runs to the actual EGR "spaceship-looking thing" on the back of the engine, then two tubes that run to the bottom of the plenum, which is what the blockoff plates are for, am I right? I was saying a bolt that fits the exhaust threading, to block off the hole from removing the tube.
