I could test the fuse connections with a multi meter to see if there is power getting to the fuses the diagram says go through. I cant understand if power is supposed to be on 24 or 29 mine is tested on 24. pin 24 has power 29 is dead. Mine is the model with the air bag style connector. So thats either a typo in the manual or that is where my problem lies.
I can try testing voltage a the fuses. But all the fuse I looked at were good.
Could the IGN relay be bad. IGN coil to where it allows the car to start but doesn't switch power. I know how relays work kinda. If a relay gets a signal it makes a connection.
My guess right now though since pin 24 is getting power. 24 probably feeds 29 but its from the circuit inside the the cluster only feed 29 when the connector is pluged into the meter board. When its unplugged the power is from 24 thats a guess.. It wouldnt make since to me if I unplug the connector from the back of the meter and I get power on both 24 and 29... If this is the case than Im getting power and my whole cluster is bad. I really want to be certain of this before I try swapping clusters.
