TLRam1 »
https://forums.nicoclub.com/tlram1-u193468.html
Mon Nov 03, 2014 10:23 pm
I have 2002 Q45, tire company (NTB) shows they can't get the rear wheels within spec.
Rear are negative 1.8 & 2.0 (left/right) degrees Camber.
According to them the car has been lowered and needs new rear springs to be raised so the rear will be within spec., I am not convinced the car has been lowered.
1. Anyone have issues with rear camber and how did you fix it?
2. What is your stock height from the ground to the bottom of the wheel well above the tire, on the front and rear so I can compare to mine? If you know yours is not stock your measurement probably would not help.
3. I have 18" rims
4. Mileage is 78,000
I will post photos of my measurements when daylight hits. Not on level ground, my rear are 27 on one side and 27 1/4 on the other side from the ground to the bottom of the wheel well above the tire. Highest point of wheel well above the tire.
My tires are stock size 245/45 18, new Michelin.
