robomatic12 wrote:You can either use the (+) or (-) outputs from the alarm brain for the door lock relays, use one and not both. I will use the (-) output below:
The wires that are coming out of the alarm brain that say to (neg) door lock output will go to your low current trigger on the door lock relays. Do you know how to wire these door lock relays? Then from the relays you will connect the higher current wires to the door lock actuator.
The starter kill relay should interupt the starter wire, and go inbetween if you get what I mean?
Thanks for re reply I dont know how to wire a relay I have seen some pics of how to wire them but most of them have two relays being wired not one ...?I have been doing some research and I found out were the green wire hooks up to.. hooks up to the wire coming from the key switch so pretty much I have all this down
White-parking lights
Black-ground for alarm brain and siren
Brown-power to siren
Red-constant 12v
STARTER RELAY
Black-starter wire
Yellow-tapped to ignition wire
I kinda get how to hook up the relays to actuator all I need now is to figure out were these wires go
3 pin 2-wire door lock harness
Green-(-)lock (+)unlock output
Blue-(-)unlock (+)lock output????
Green-key switch wire
