NCJack »
https://forums.nicoclub.com/ncjack-u154937.html
Sat Jul 17, 2010 2:55 pm
Air conditioners are serviced and filled based on volume of coolant, and not just pressure. If you added a can yourself, and the compressor stops engaging, use a pointy tool to depress on the low side valve to release some pressure like you would a bike tire.
If the AC is intermittent, that would indicate moisture or air in the system, causing freezing in the condensor (or is it the evaporator?).
Either way, pray that it stabilizes after a few driving hours, or attempt to drain some out like i said and refill according to the directions on the can. If you want it done right, take it to a pro, they have the tools to do this right and legally.
Regards,
Jack
