loystock »
https://forums.nicoclub.com/loystock-u10145.html
Wed Jun 27, 2012 12:53 pm
Welcome to NICO.
YOu can get a lot of info from the 'sticky' "The Most Important..." in this forum. In fact, the SRS Reset Procedure is there...
How to reset SRS(air bag) light:
Open the driver's door. Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver's Door Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7 seconds after turning the ignition switch ON. Turn the ignition OFF. Close the driver's door. Start the engine.
If the airbag warning lamp is still on (or still flashing), there is a fault in the Supplemental Restraint System which must be diagnosed and repaired. This is a job for your local friendly Nissan dealer.
