GsaSlick »
https://forums.nicoclub.com/gsaslick-u132614.html
Mon Feb 22, 2010 9:21 pm
Good injectors will ohm between 10-14, and if you're going to replace one especially if they're all original, you should replace them all while you're down there if you can, because Ace is right they'll all go sooner or later. I believe that 90-92 and the 93 convertible use the "old style" square top injectors, and the 93+ (minus the vert) all used the "new style" round top injectors. Hate to see you have to do it, it can be pricey and a pita if you haven't removed the plenum before, but all in all I'd say my injector problems led to a ton of knowledge and at least I can take that away.
Good luck hope you can get that taken care of.
