F4ucc »
https://forums.nicoclub.com/f4ucc-u3905.html
Mon Feb 03, 2003 7:11 pm
Hi that180SX.
Well, my KG/MM is rated as "RACING" on KG/MM's list as I prefer single spring rate. Hum, it really depends on how you use the car, prograssive springs provide both comfort and some serious street drving, however it sucks on track at least I feel that way.
I bought my KG/MM S-21 from a local shop "named AUTOFIX" in Bayarea. If my memory serves me correctly I paid around 300 shipped which is probably the cheapest that I could find. " Lots guys ask for 350+"
As far as ride goes, I feel quite comfortable as long as I set HTS on soft side about 6-7 turns from stiffest setting. By the way, since HTS lacks rebound damper, which is intentionally designed that way for drifiting, you kind of feel the car tend to float around over bump. If you don't use HTS for drifting, perhaps Koni sports would be a better choice as Koni provides much more rebound damper. You have to be a good driver to drift KONI, otherwise you will have to spend lots of energy fighting fishtail!!
Oh, I got my HTS directly from one of my buddies in Japan which saves me lots of $$. If you have to pay more than $650 shipped, perhaps KYB AGX is a better choice since they are more like $350-400 a set. Somehow, Tein HE seems to be a best buy. around $1350, I guess.
My case, I paid nearly $1000 for HTS,S-21 springs, and CUSCO adj front camber plates PLUS some mis-items such as new shock bushings..etc. Still, I don't have the beauty of height adjustment provided by coilover. It's really up to you.
Hum, went to last drifting event with my setup, WOW......much easier to handle the drift angle and you have lot more time to correct the car while staying sideways.
PS: I feel that 6.6 kg/mm is still too soft on race track I might go with 8kg/mm with custom-mde coilover for front shocks eventually.
Just my thought.
