I have an apointment with a patenting company in chicago that matches people with ideas (similar to this) with companies looking product ideas. Apparently, there will also be a patent attorney at the meeting as well.wyntka wrote:Get the patent man! Good idea.
You wouldn't need constant power with non-volatile memory. Just use Flash memory. It's getting faster and cheaper all the time. It is also much more compact than magnetic memory. Then there's the additional bonus of needing less power while in use (as well as not needing power when not in use).The big drawback with Flash is that common formats don't come in very large capacities compared to hard drives.BUT that should be changing, soon. Manufacturers are starting to see the potential of modern high-speed Flash memory as an alternative to compact hard drives. It's only a matter of time until ultra-high-capacity flash modules hit the market. Once you've got a 250GB flash drive (and I'm not talking about some industry-standard flash CARD in need of a decoder chip and card slot, I mean a real flash DRIVE that's one single integrated unit that's free of goofy portable-media and DRM restriction horsepucky), you'll be able to store all your music in a totally non-volatile, power-efficient setting.Darktide wrote:that would be terrific. I hate to burst the bubble though. It would need a constant connection to the battery and that could cause some problems with dead or dying batteries or if someone lets their car sit for a while. If you could find a way around that that'd be a terrific idea. Definitely get ahold of Pioneer...
Bluetooth has already been integrated into aftermarket stereos, which is why I cant even use the term "Bluetooth" in my presentation to the company. It would be an infringment of the Bluetooth trademark. However, WIFI has not been used in conjunction with any type of car stereo equipment.Darktide wrote:Well, my suggestion to you would be to let the unit have a capacitor of sorts so that it can store power every time the car is turned on. Maybe like a lithium ion battery or something that can recharge easily and then it'll run off that for say, 8-24 hours so that you have time to connect and do your thing. It'd have to be a secure connection too, you wouldn't want someone to be able to just go in and start altering stuff on the hard drive.
Wireless chips are getting smaller and smaller these days. It shouldn't be too hard to do it the only unfortunate thing is that wireless doesn't have an amazing distance so the car would have to be pretty close to the house. Maybe a bluetooth connection so it can link up with a laptop would be another good idea... *shrug* Good luck. Becareful that that company doesn't screw you over, I've heard some shady things about them.
Bluetooth is also VERY low bandwidth; not adequate for streaming media.ZGadson wrote:Also, I believe Bluetooth is meant for short distances (10-20 feet or less) - which is why if you've got a bluetooth headset for your cell, and you put your phone down and walk away while using the headset, you quickly get static in your ear instead of the other person on the line.
That's why WEP and WPA encoding for wireless networks were invented. Units could be setup with a user name and password to gain wireless access, which could then give multiple drivers the ability to setup their own playlist if they wanted to.blazncypher wrote:by sharing your media through wifi with the unit it would open up lines for hackers, thats the problem with wifi, make sure you have a good firewall. you wouldnt want someone to hack into your stereo and implant a virus in your hard drive.
The whole purpose of this in-dash system is to eliminate the need for such devices. iPods, USB drives, and the like are a hassle, as are all the wires hanging from your dash.MinisterofDOOM wrote:Yeah, the QX has 9.3 GB hdd for music. It also has a CF card slot (Why CF of all formats I can't fathom...but it's better than nothing I guess).
I HIGHLY doubt any in-car audio system will be able to copy songs from an ipod. It's hard enough to get them off an iPod and onto a PC or Mac. Apple doesn't like the idea.
Using the flash card slot, though, you could move music to the car pretty easily (supports MP3 and WMA). And it'll rip from CD as well.
(Must we yell? Easy on the caps key, bud.)blazncypher wrote:ECLIPSE MAKE A DD UNIT THAT HAS A HD THAT WILL COPY THE MUSIC FROM YOUR CD WHEN PLAYED. IT WILL THEN CREATE A PLAYLIST OF THE MUSIC STORED ON THE HD
Thats part of why I have to physically go and present my idea to the US Patent Office. Although you're right about not being able to patent an idea, I can patent the use and combination of certain term. For example, say Pioneer wants to make a GPS system with WiFi capabilities - because this has not yet been done, I can pattent the use of the terms "GPS" and WiFi" so that they cannot be legally used together by Pioneer.blazncypher wrote:wow why does everyone freak out about caps, whatever.......i was talking with my buddy who is a program designer and he thinks he knows how to make this work. the thing i found out about patents is you cant patent an idea only a technology so you would need to show them how this works and you would have to know how to make it work not just have the idea to do it.
