Larz »
https://forums.nicoclub.com/larz-u216291.html
Tue Jun 25, 2013 12:51 pm
I also heard that. However, it's not true. The key slot is there soley to be used when your smart key has gone dead, OR can no longer transmit codes to the car - the slot reads the code direct from the smart key instead of receiving code remotely.
If I were you, Van, I'd follow Enigma's advise - buy another battery - check the manual for ther correct model# battery needed and stay with a quality brand like Duracel instead of a store-brand copy. After you have tried TWO different batteries and still can't get the smart key to communicate with the car remotely, I would search for a local locksmith who specializes in programming smart keys. That would probably be less expensive than having the dealer do it.
