chad b. wrote:are you getting normal readings from the TPS, MAP, and IAT?
Yes, they seem to be reading okay. TPS has a range of .5V to 4.2V, MAP reads 1.67V, 0 PSIG at KOEO, IAT reads correct temp. You had an issue with TPS and MAP wiring with your wiring specialties harness, correct?
StockAsFuhS14 wrote:ive never heard of a vehicle cranking but not starting while having fuel and spark unless its on the wrong stroke mechanically.... so id love to hear how this turns out...what about CKP?
True, but if the fuel or spark is timed incorrectly, she won't start either. Cam and crank signal from the CAS seem to be okay, at least from the AEM screen.
The car actually started (ran poorly and on 5cyl) when we changed the 'number of teeth' setting on the wheel to 20 (if I remember correctly, a friend was working the car at this time)
boostedh23a1 wrote:post a screenshot of your Coils/Inj Tab.
Thanks!
Dan
