Zviator wrote:Eventhough I'm not a brand whore, I definitely will do a HW on quality beforehand.
Can someone please just answer my original question ?
Thank you,
I'll be nice and save you the trouble. Ebay parts suck. The heim joint, the most important prt of a suspension arm, always goes bad. They either sieze, squeak, or just fail completely which is totally unsafe. Get Powertrix as they run quality heim joints and bearings in all their arms to prevent such failures.
For camber adjustment, I'd recommend front upper control arms, tension rods, and rear upper control arms. All these components wiill keep your camber in check. And the aftermarket tension rods will save the bearings in your FUCAs from failing prematurely. If you don't wanna fork over the cash for FUCAs, you can also get the 300 degree camber kit with gives you some but limited camber adjustability.
