LOLDarkKnight22 wrote:Alright well since my 2 12" alpine type R's from my old Grand Prix won't fit in this overly spacious trunk of the A/C I have to go shopping.
Me being the Rockford Fosgate fan that I am, my suggestion is the Rockford T2 10" subwoofer... or the T210D4 sub! It can also handle 1000W RMS easily!I'm personally going with the T212D4 subwoofer, which is the 12" version! It'll be powered by the Rockford T1500-1bd amplifier!DarkKnight22 wrote:Since I'm thinking I'll probably get a quicker response here I'll go ahead and post again.
I have a Hifonics Brutus BXi1606D @ 2 ohms pushing about 1100Wx1 channel. Seeing as how a 10" sub would be the best fit I need some good recommendations.
Just because of space I was thinking about getting just 1 10" and going to town on it. I'm more interested in SQ but at 1100W I have a feeling it's going to be leaning more towards SPL.
The first thought was the Alpine Type X 10" which can take 1000W easily with a max of 3000, but I'm not sure if that's going to be awful SQ wise.
Next question is I have the bose setup right now. I want to keep the stock HU (like it's look and don't want to lose the bluetooth) so I'm assuming I'd just run a LLC from the wires going to the stock subs in the back deck?
And if I add the sub, it would probably be better to just disable the rear deck subs all together since they obviously can't compete with a trunk sub right?
Thanks!
"Blue Magic is a brand name! like Pepsi, that's a brand name! I stand behind it, I gaurantee it!" ... American Gangster (lol)DarkKnight22 wrote:lol Doc do you work for RF?
It seems those subs are getting harder and harder to find. Any other good 10" 1000W subs?
Nifty, do you have that W3 hooked up to your 1100W amp?
btw, where is the Bose amp in our car?
A few questions...rjdmmfl1 wrote:1 last thing, the Bose amp is mounted upside down in the trunk between the rear deck speakers!
1.No, you need at least 200W or more, that Bose won't be able to handle it plus......see #2maxentropy wrote:
A few questions...
1) Will the Bose Speakers & Amp push out enough Highs + Mids if I install dual 10 subs? I would probably turn the bass down on my Nav unit EQ and keep the Treble around mid or perhaps a little higher...
2) Is it possible to replace the Bose amp to push more power to the Bose Speakers?
Question #1... NO. At high volumes, they will NOT keep up with two 10" woofers.. you won't hear any words, just bass! Too much trebel will distort at higher volume with the Bose Headunit!maxentropy wrote:
A few questions...
Its not that amps aren't stable at 3 ohm, its that hardly no one uses 3 ohm woofers and speakers, so most companies don't put them on their amp specs. If your amp is stable at 2 ohms, then your amp will peform fine at 3ohms, its just that the power output will be between what it would be at 4 ohm or 3 ohm !darkKnight22 wrote: Doc, here's my issue with the W7, the nominal impedance is 3 ohms. My amp (and most others besides JL's) aren't stable at 3 ohms, and I def don't have the money for a new JL amp.
You really should give Hifonics a chance, they are better then most people think. It's a lesser known brand then the big ones but it can hold it's own and I've had it for 2 years without a problem.
OK,..so I'm thinking of doing what maxentropy is doing and keeping the stock system and adding on a separate amp and 1 10" sub to get a little more thump out of the bass. Just to get this clear in my head, the stock amp is mounted between the rear deck speakers. So I am assuming that there is a wire harness where the speaker wires goes into and goes out to..correct? I just need to tap into the speaker wires that is designated for the rear 6x9s before it hits the amp and splice in a Good Quality Hi-Lo converter. From there, I can plug in a quality RCA cable into the amp and from the amp into the 10" sub.rjdmmfl1 wrote:OK, if you want to keep your factory unit, you have a few options... you can get a Hi lo converter, and piggy back of of the rear speaker wires before they reach the BOSE amplifier.
Hey guys, I found this for the 2007 Altima SedanDarkKnight22 wrote:Correct for the LLC. I don't know the wire for the lows, still working on that part. I went into my trunk for a second last night and that amp must be pretty well hidden, I'm going to have to tear through some carpet to get to it lol. I see a how-to guide in the near future lol.
Thanks Doc for confirming the wires! Question though, which ones are the wires that goes into the amp? If I'm going to splice in an LLC, do I hook it up to the orange/black for the LR and Blue for the RR? or White/Red for the LR and Black/White for the RR?rjdmmfl1 wrote:Speaker colors for the Altima Coupe...
LF Speaker (+) WHITE LF Speaker (-) BLACK RF Speaker (+) GREEN/WHITE RF Speaker (-) BROWN LR Speaker (+) ORANGE/BLACK LR Speaker (-) WHITE/RED RR Speaker (+) BLUE RR Speaker (-) BLACK/WHITE
yes, amp is between the rear speakers.. just pull down the grey cloth and its theredangeris wrote:
Also did you confirm the location of the amp as well? Is it in between the rear speakers?
who gets the Bose Navi and replaces the headunit????? Isn't that a waste of money?MikeisSUPERBAD wrote:anybody care to post pics of your set up (amp & sub added to bose stereo)
also for those who have the bose navi... and have replaced the unit with an aftermarket... which did you get? how much was the cost? and what features or benefits were there because of this?
Oh duh! Sorry Doc! I don't know what the hell I was thinking! of course. positive and negative.. Sorry for the idiotic question. Was having a Geritol moment.rjdmmfl1 wrote:
well, for the high-low converter, you will have a positive and negative wire for each speaker... so for the rear right (RR) speaker, hook the positive on the high-lo converter to the blue wire, and hook the negative on the high lo converter to the black/white wire!
