DevonD wrote: do you have an air intake? that makes a sound nicer than any blow off valve!!
I agree 100%AZhitman wrote:Please, please don't.
Do it right, or don't do it.
Poser faux parts are for ricers.
http://www.turbokits.com/maxima_turbo_kits.htmlAcMav wrote:I'd like to say that 3,600 doesn't include a boost controller, new ECU, larger fuel injectors, new lower end to reduce compression, or 9 of the other things you'd want to do first, or NEED to do. This is way out of the scale of something cheap and easy to do. I Would consider an engine swap to be almost as easy as boosting a N/A Engine in this case. Unless your willing to throw down megamoney (4-5k) I wouldn't bother even thinking of your "Pewwwwww" sound.
Dude, that's like bolting on a big **s hood scoop when nothing even pokes through the metal...D_roc wrote:is it possible to do i i just love the sound it makes,and no the littles whistle thigns they sell on eaby suck
Im running 12psi on a stock VQ30 with 224k. No need to rebuild just make sure the tune is up to par.MaximA32 wrote:http://www.turbokits.com/maxima_turbo_kits.html
That kit includes brand new Garrett GT2871R, FMIC, piggy-back fuel management, 2 injectors, internal wastegate, adapter plate, downpipe w/ gasket, TSI injection control unit w, turbo timer and as I said, all associated hardware, fittings and lines. As I stated before, this is a complete kit.
As for the bottom end rebuild, sure, you can do that and it'll lower the compression but isn't necessary with this kit. The VQ series motor can handle up to the 8psi that this kit is saying it will run.
Come to think of it, the HLH 4g Maxima ran somthing like 14psi on a stock bottom end IIRC. So as for building the bottom end, nonsense I say as long as you stay at or under the 8psi that they reccommend.
where you been? so if i wanted to get a custom lim and bolt on an eaton sc from gm's 3800 series II would i need bigger injectors and a diferent maf? it puts out 9psi stock.kzoosho wrote:
Its almost not worth it to even try a setup like that with the cost being very high. You would be better off to do a turbo setup and that way you can increase boost when you want or need. And you would end up with more power man.allensteiner wrote:where you been? so if i wanted to get a custom lim and bolt on an eaton sc from gm's 3800 series II would i need bigger injectors and a diferent maf? it puts out 9psi stock.
Doing a one off is never the cheap route just to let you know. If you are looking for a bolt on turbo kit then yes 3500 is what youa re looking at. But if you doa custom setup you can have it done for 2500 or less . But i mean i guess go ahead and try it . U never know it may be cheaper. I know i personally wouldnt do it.allensteiner wrote:see it's the cost i'm thinking about. $200 for a sc from a junkyard, adapter to mount on lim - dunno how much yet - injectors, maf and safc less than $2k. a turbo kit starts over $3500 with just the blower and piping. i'd go crazy spending but life happens...and i have a wife and a baby girl to support so gonna have to go cheap on boosting
I ran the stock maf for a year and just went to a Q45 maf because of the turbo change. i think the stock maf will handle 300hp of air not 300hp. The current turbo i have can push more cfms than the stock maf can handle so i opted to use a larger one. Also for a low boost setup or in my case my setup the safcII and wideband is a perfect setup. I can tune with it and have no problems getting my a/f right.allensteiner wrote:i gotta be cheap so unfortunately i have to try...i thought about taking the exhaust part off of a turbo, replacing the inner bearing so i wouldn't have to run oil, putting a pulley on that side and running that off my belt as a sc. that might be even less expensive. but that aside, i see you have diferent mafs on your boosted cars. can the stock max maf not handle boost? i thought that safc would be enough for air/fuel adjustment.
The main problem with that is compressor speed. Turbo compressors can spin upwards of 100,000+ RPM to flow the air desired whereas most centrifugal superchargers spin up to maybe 55,000 RPM and are internally geared to spin the impeller faster. Say your engine redlines at 7,000 RPM and the desired boost pressure requires 100,000 RPM with the turbo, that would require a pulley ratio of 14.3:1... meaning, you would need a 14.3" pulley on the engine and a 1" pulley on the turbo to hit 100,000 RPM at your 7,000 RPM redline. 14.3" is huge and 1" is pretty small for a pulley, basically there's not much metal there for the belt to get very good grip so there would likely be quite a bit of belt slip.allensteiner wrote:i thought about taking the exhaust part off of a turbo, replacing the inner bearing so i wouldn't have to run oil, putting a pulley on that side and running that off my belt as a sc.
I have pics of everything. I also did run the stock injectors,maf,and fuel pump for a year but i dont recomend it at all. My injectors were at 95% duty cycle under boost so not safe at all. Also i had to run 60psi of fuel pressure to keep from leaning out which is not a safe thing to do. I would say a walbro 255 and afpr on stock injectors and maf are ok to about 300hp, after that you need to upgrade everything. here are a couple pics of the car with my old setup.AcMav wrote:Oh god why would you ever post that, Now he will go do it.
Ive been personally considering doing what Kzoosho did and turboing my car except for the fact i'd rather get my suspension done first. I have access to a stock turbo off a Gen 9 Evo that could be placed in.
Seeing that we are going offtopic and changing this into a turbo discussion, i have a few questions for Kzoosho, Does the stock fuel pump put out enough fuel pressure for the forced induction? Did you have to move to a higher gauge fuel line?
Do you have any pictures of your intake/exhaust setup? Is there enough room under the hood for all this? And did you cut apart the front bumper to fit in an intercooler?
