Actual HP Gains!
Nissan 350z / Nissan 370z general community discussion forum
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Just thought I'd piece this together for those shopping for power, this is based on actual dyno's done by people that aren't me.
Used 350Z's can be had for under $20,000, they make 287 hp so they cost $69.69 per hp
Say you want more power, many people go for the intake manifold and or plenum spacer, this is based on the independent results found at g35driver.com http://g35driver.com/forums/sh...96688
MREV2 (retail; $399) + 5/16 ISO spacer (retail; $299) =
+5WHP ($698/5=$139.60 per whp gained)
In the winter 06 issue of Sport Z, they did an intake shootout and tested the motordyne 1/2 spacer with the stock intake and yielded a 10.2 hp gain, in the same test the 5/16 spacer with the stock intake yielded 6.1 hp gain?? At any rate the 1/2 spacer $265 / 10.2 hp = $25.98 per hp5/16 spacer $235 / 6.1 hp = $38.63 per hp
in ten fall 04 issue of Sport Z Magazine they tested a couple of popular combo's and found that the Injen Cold air intake, with the Crawford Plenum and the Injen Exhaust at a total cost of about $1500 / 19.5 hp gain = $76.93 per hp
Want exhaust? the Sport Z Magazine 2003 exhaust shootout winner was Borla (I'd love a more update exhaust test if anyone knows of one please link it in) http://www.stillen.com/media_f...7.pdf (stillen was a very close second at 8.1 hp and actually made more torque but costs a good bit more)Retail price $845.49/ peak 8.2 whp gain = $103.16 per hp
Now say you want to upgrade to forced induction, summer 05 of Sport Z Magazine shows us that the JWT kit makes 166 whp over stock! At $6895 / 166 whp = $41.54, this just keeps getting better
Spring 04 sc shoot out showed us that the ATI Procharger kit make a whopping 111 hp! At a retail price of $5799 / 111 hp = $52.25 per hp!
Last but not least, add lightness! Lightweight wheels and lightweight flywheel instead of adding heavy subwoofers and speaker box's, listen to the music emanating from under hood, and if you spend all your money on go fast parts and can't afford to eat you'll loose weight and be even faster
A lightweight battery or lightweight seats can save a few lbs, if you’re really crazy you can strip out the entire interior including the heat and a/c, then you can start removing sound deadening and undercoating but most of you aren’t crazy enough for such tactics.
Andy_V35Sky_350GT
Car: 2003 Nissan Skyline 350GT
Thats some excellent info, getting the 1/2 spacer soon. I had alot of trouble with intakes, actually doing worse than the stock so I stuck with that (and its pretty good to start with).
I have Nismo exhaust, it yielded a 10 rwhp increase, but thats on a 350G, not a Z.
flyguy2618
Car: 06 nissan 350Z
Do you know if you get a 1/2 spacer for a Z will the front strut bar still be able to fit over it or do you have to loose it?
evildky
06 Nissan 350Z GT
if there isn'tenough room, you could always add a couple of spacers under the bar , or just get one fo the bars intended for use with custom intakes
504 350z
Car: 2007 black 350z
flyguy2618 wrote:Do you know if you get a 1/2 spacer for a Z will the front strut bar still be able to fit over it or do you have to loose it?
you have to loose it. as evildky stated you can get a stillen brace for use with custom intakes
PerfectApex
Car: 2007 Grand Touring Coupe 350Z & 1999 Viper GTS-R (700hp)
Your "last but not least statement" was the best!!!!!!!! Spot on and well said!!!
evildky
06 Nissan 350Z GT
I justthink it's funny when people say they got the carbon fiber hood to save weight and are rolling on 20" wheels and a pair of subs in the back
PerfectApex
evildky wrote:I justthink it's funny when people say they got the carbon fiber hood to save weight and are rolling on 20" wheels and a pair of subs in the back
LMAO and how right you are!!!!!!
gtnmwet
Car: 03' 350z
you got a beautiful ride Andy!
NSRsheets
Car: 2009 Nismo 370Z #85,1993 Nissan 240sx RB25DET coupe, 2013 focus
Very good article. Lots of great points. Speaker boxes and huge wheels FTL!!!
Low_Cost
Car: 2004 Nissan 350z Touring Ed.
20's ftl. I think they look stupid on the Z, in fact, I saw one yesterday with some Chrome 20's... (he also had a chrome grill, chrome door handles, chrome trim... it was almost as bad as that blue ricer 350z that was "supercharged" with like 20 stick-on scoops... )
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
Adding to the original post, Turbonetics comeplete single turbo kit increases the stock 287hp to 450hp, thats 163hp increase, which is 3hp less than the JWT twin kit, but it is less than $5000, actually $4800 at turbokits.com. $29.45 per HP. Thats something to think about.
Also, as far as planums and spacers, i went with the Kinetix V+ plenum ($300) allows a lot more air and is made of composite plastic so you are actually reducing weight instead of increasing it, by adding a spacer. The dyno results are 14rwhp+ increase. $21.43 per HP + weight reductiong of (i think) 3 lbs. The plenum comes with all required hardware including strut bar spacers because the plenum is so much larger that it requires the sturt bar to be raised a bit, but your stock hood will have no trouble with clearance, i assure you.
bkreitzer
Car: 2007 Nismo - Redline - #0550 - more info in my Bio
I cannot seem to quickly locate the plenum spacers for the '07+. Has anyone found out if there are spacers for the newer Z's?
evildky
06 Nissan 350Z GT
I covered the JWT kit and the result I found was +166 whp, but 3 hp could be noise in the data, I also used published price at the time of the article, I'm sure most of these prices could be improved upon, I welcome additions to this thread but please post your sources for hp and pricing, and please do not include manufacturer advertized hp gains as motorsyne has shown up they are not advertising peak gains
bmike818
Car: 2007 Z
bkreitzer wrote:I cannot seem to quickly locate the plenum spacers for the '07+. Has anyone found out if there are spacers for the newer Z's?
We have a different motor. SO far we don't have any for the HR engines that I know of.
Andy_V35Sky_350GT wrote:Thats some excellent info, getting the 1/2 spacer soon. I had alot of trouble with intakes, actually doing worse than the stock so I stuck with that (and its pretty good to start with).
Did you reset your ECU by unplugging your car's battery after installing the intake?
Return to “350z / 370z Discussion”
