Trnqld wrote:Had a chance to pull the g sensor on the 92a, part number 98805 61u01 followed by 407940-5110 . Found one out of a 95a 98805 61u01 but changes to 407940-5111, both are made by Zexel 17121 out of the 92a and 46820 from the 95a. Are they interchangeable ???
absolutely interchangeable.
btw, haven't been on the forum that much, but your earlier post about no codes, yet the actsus light stying on and active control in fail-safe is a CLASSIC sign of the active ECU going bad. regrettable that this happens.
Never EVER let your battery get weak. check your alternator and replace immediately if it is not 13.8 to 14.5 v. low voltage FRIES the active ECU.
I have AGM batteries in both active G50s and will even trickle charge them if they are going to sit for more than a week.
