Buzzman »
https://forums.nicoclub.com/buzzman-u55955.html
Mon Jun 30, 2008 12:25 pm
Don't be so sure it's the drain hose. I've had water come in on the passenger side, soaking the carpet. Apparently so have a few others.I first thought the same as you, that it was the AC drain hose, until I realized the carpet was still getting wet when it rained.Are you sure it only gets wet when you have the AC on??If you need to find the drain, it is in the engine compartment, on the firewall, low down, almost dead centre. It's basically just a rubber hose pointing down. Run the truck with the AC on in the driveway or in a parking lot, and see if you get the telltale water drops in the driveway. If it drips, then the hose is OK.As for mine, I have never been 100% positive of exactly where the water came from. I narrowed it down using a garden hose, and figured the water was coming in at the base of the windshield on the passenger side. I used some silicone caulking to seal every little crevace and hole along the base of the windshield, and the upper firewall, and it stopped.Good luck.
