I can assure you its not a line, I wish it was a line as a matter of fact.elwesso wrote:Where exactly is it leaking? My concern is that its not actually the unit but a line...
I have a couple 90-93 ABS actuators in my attic..
So thats a no?BCC93QT wrote:I have a leaking one i need to fix.... when work is not so time consuming. The one im running now doesn't work but i really don't like ABS so i haven't even bothered. Spring time is coming i cant friggin wait. Need a good wash/wax shampooing and cleaning
Heath I told you already how I pick my used parts, any chance you can keep and eye or two out for Q's that meet those requirements?Q451990 wrote:I can always pull one that looks good at the pull-a-part for you if you need one. I agree that you should check the lines in the area too.
Heath
Infinitiguy19 wrote:How much do they usually charge for the ABS Actuator? If you are going to a pick and pull, How much more is the 12 month warranty?
Any ABS Actuator from a Q45 made in 07/1990 to 02/1993 will fit in my car. And it does matter if the car has TCS or not as its all the same.
I called A1 Cardone and they said to bring the ABS Actuator to a NAPA store to get a "Guesstimate". For anyone else who went to A1 Cardone's website and failed to find a telephone number here it is: 1-888-280-8324
The dealer looked up those part numbers and the Month and Year Q45 they apply too.Q451990 wrote:I'm pretty sure the 90-92 (and maybe '93) are the same? Someone with FAST could confirm that.
Heath
No there are only those 3 ABS actuators listed for all G50...qship96 wrote:maybe ALL 90-93 use 3 channel ABS, while later 94-96 use 4 channel ABS only on TCS equipped models?
I am almost positive I have 2 90-93 ones.. No idea on the particulars, but to make you feel good they came from a 92 model with 65,000 miles that the owner got rid of due to excessive bird poo on the trunk lid.Infinitiguy19 wrote:Wes do you remember from what cars you pull the ABS Actuators from? Were they in an accident?
elwesso wrote:No idea on the particulars, but to make you feel good they came from a 92 model with 65,000 miles that the owner got rid of due to excessive bird poo on the trunk lid.
My understanding is all TCS are 4 four channel and all non TCS are 3 channel.elwesso wrote:I think the TCS vs non TCS is the same for the ABS actuators, because 2 lines feed the front brakes, then one line feeds the rear as you said.
