A little weekend project for the RB
robbie2883
Car: 1998 RB25 Kouki
NO MORE GAUGE PODS! YAY!
finally got a chance to finish up the gauge cluster. just need to ground an extra pin for the speedo to work and pull the old gauges down then i'm done!
VVV-VIDEO-VVV
Carl H
pretty cool, how do you like those defi MFDs?
robbie2883
i love them, especially since they read speed correctly. (my oem was off due to q45 rear end swap) i have any reading i want out of them with warning for every sensor. boost, egt, oil temp, oil pressure, fuel pressure, water temp, speed and tach. i can display up to 4 sensors at a time...but warning work on all of them whether they are displayed or not.
Shocker
Car: 89 240sxHB rb26/30
robbie2883 wrote:i love them, especially since they read speed correctly. (my oem was off due to q45 rear end swap) i have any reading i want out of them with warning for every sensor. boost, egt, oil temp, oil pressure, fuel pressure, water temp, speed and tach. i can display up to 4 sensors at a time...but warning work on all of them whether they are displayed or not.
Whats MFD stand for? I'm on their site and cant figure it out... how does the gauge take the speed signal and convert it to what you need? Was it set by you once you establish your speed via gps or something and set the defi to match?
Looks pretty good!
robbie2883
yeah...it has standard pulse modes and then you can also custom calibrate by going a set speed and setting it. i just used the gps on my nav to verify speed and it seems to be dead on now. look up the defi link display. MFD stands for "multi-function display"
