seang »
https://forums.nicoclub.com/seang-u122444.html
Mon Feb 08, 2010 9:52 pm
Also, there are close ratio gear kits available for the FS5W71C, at least for the 240sx vrsion. I don't know if they would fit the hardbody version, but you never know. Maybe (if it would work with the truck block) you could even use a 240 transmission with the gear set, which, by the way, is made by OSGiken. They might have discontinued them, but I'm not 100% sure.
My 1st gear is a 3.92 for my 4wd compared to your 2wd's 3.2?, so at least you got a leg up on me. I gotta hit second by 22mph max. It is good for some things, though.
I'm not sure if the ratios are different between 2wd HB's and 240's, but you can Google "fs5w71c gear ratios" for an answer if you are so inclined.
