I did find this part number in a previous post...
Nissan Bulb 27545-1W600
Thanks!
I'd assume it'd be possible to just find some 12V LEDs and replace the bulbs with LEDs, then. I might try that depending on how much clearance there is in the buttons. Do you happen to have any pictures of your unit disassembled?jpedderson wrote:Just changed out the bulbs with parts from Radio Shack following instructions in this post: http://www.nicoclub.com/archives/climat ... ement.html
The original Nissan part is the Nissan Bulb No. 28529-10y00. I bought the following bulb at Radio Shack to replace the tiny Nissan bulb and retained the blue bulb covering:
http://www.radioshack.com/product/index ... Id=2103780
12V Microlamps (2-Pack)
Model: 272-1092| Catalog #: 272-1092
I also used the same bulbs to fix my rear defroster button and a seat heater lamp (that was a pain taking the switch apart).
The LED points down, so the light would probably not be as bright. If anything I think the HP LEDs are slightly shorter than the regular LEDs, but there's really not much room in the button housings at all. Unfortunately I didn't take any pictures of the interior of the button housing looking directly in from the front.jpedderson wrote:What are the dimensions of the HP LEDS? They look different than the regular ones. Maybe theres room to shave a regular one? There's a lot of lens on there before you get to the LED element. Does that button light from the side? You almost have to shave the front to a point to get light sideways out the top...hmm.
