So the blower motor only operates on high? it's as if the Blower Motor Resistor is unplugged... & a shop gives you a quote...
--- HEAD FOR THE EXIT AND READ THE FOLLOWING: ---
for 1998 - 2002 Nissan Quest or Mercury Villager
the FSM is kinda vague on the drawings, having some people contemplating on removing the glovebox or not... so I'll just post the pixIf you look underneath the glove compartment you can see the resistor. It will have 4 wires running to it. It is held in by two screws. I believe it takes an 8 mm socket. The screw in front is easily visible. There is another in back. Take out the screws and the resistor will slide down and out.
you can move that rubber pipe out of the way to access the rear screw; it only slips on/off
push that brown tab in with the help of a flathead screwdriver if you have marshmallow fingers
Weird that this would blow instead of the fuses in the fusebox. I changed this 2x already (the 1st time as a 2nd owner in 2008)
reminds me of the white box in the 240sx - they also blow like this instead of the fuse (no-lights on dash)
weird that it blew in 2 different spots...
sigh (made in Mexico) Autozone # JA 1399 Lifetime Warranty
(Duralast products are engineered and manufactured by Wells Manufacturing) so I'm covered with the cost of the part
Done in 5 minutes & chilled out with my NICO-tot for the rest of that suggested hour...
if pix are bad, sorry they were taken with an old cellphone
