Having some issues with the condenser fans on my 98 Q45t. The fans do not come on at all. Turning on the AC, they do not come on. Connecting power directly to them and they work. Fan motors sound fine. Also, I have checked the relays per the FSM and they check out fine too. I have also tried another brand new relay. Weird thing is, when I jump the relays, the fans come on so that should indicate continuity through the circuit. Something is causing the circuit not to get continuity once the relays are connected, which is causing me to lose my mind
The fans do not kick in even when the temperature reaches above 95 Celsius. I am getting the reading from the OBD2 scanner via consult. The weird thing is, the temperature reading reads funny sometimes. When the car is idling, I rev it to about 3500 RPM and the temperature reading on the ODB2 scanner will actually drop a degree or 2 and then when I let off, the scanner reading will rise.
Initial reason as to why to troubleshoot fan issues is due to the A/C not getting cold when its fairly humid outside. When the temps are bellow 79 degrees and it gets somewhat cold. Recently had the A/C vacuumed and recharged. Honestly not 100% sure that the shop did fill it to proper pressure levels but assuming they did. The whole A/C system has been rebuilt as of recent and before the vacuum and recharge. Replaced evap core, dryer, condenser, and compressor. Did not replace the Triple Pressure Switch on top of the dryer but I assume it works properly due to the fact that once disconnected, the compressor turns off (not a clear indication, I know).
Any ideas?
