jmaxima »
https://forums.nicoclub.com/jmaxima-u47671.html
Tue Sep 26, 2006 8:25 am
Anyone ever picked up a 1706 code before, with a manual tranny?
It's a '99 Max SE-L with roughly 175,000 miles - original clutch if that matters. It's been pulling this code for a while now. FSM doesn't give a whole lot of info regarding signs and symptoms of a bad PNP switch/sensor in a manual tranny car. The local dealership service department told me that it's impossible - manual tranny doesn't have one. But, the FSM indicates they are incorrect - as usual. I don't want to pay them to diagnose the same thing and still be clueless as to the solution or if it really needs to be replaced.
Car occasionally idles low after warm up. And has stalled a couple times when idling or taking a low speed turn with the clutch in. Those symptoms are similar to having a bad coil pack (or spark plug), or mass air flow. But I don't have any other codes currently.
Thanks,
James
