Slumpert »
https://forums.nicoclub.com/slumpert-u216156.html
Thu May 30, 2013 9:09 pm
Having just done this recently. Be sure to have them order new rear water hoses, new egr gasket, intake gasket before they start work. Consider having them replace the few vacume hoses under there.
Can consider checking the knock sensor. It likely is dead (does not turn on engine light but does show as code on scan). And as said above that is a goodtime to change plugs.
