Caligulastank »
https://forums.nicoclub.com/caligulastank-u248749.html
Tue May 19, 2015 6:10 pm
Thanks for the info guys! Very helpful. So far I have replaced with new: water pump, fuel pump, fuel filter, radiator, hoses, belts, air intake temp sensor, cleaned and repacked bearings in pulleys (they make some noise but are still useable) took apart the intake (did not remove intake manifold) and put a new air filter in and cleaned the MAF and throttle body. This car is in excellent shape inside and out but some of the stuff under the hood needs some attention, but thankfully the car has been garage kept almost its entire 17 year life and never sat up. Right now the car runs pretty well with the accessories off because of the drag of the pulleys, but im still having some hesitation issues at the low end. Hooked the car up to a computer and the only snapshot it had was the coolant temp sensor thought it was -40 at some point (i live in texas). However, upon checking the spark plugs i discovered the oil leaking from the valve covers. i only removed one so i dont know if the leak is on both sides or the extent of the damage. I have managed to purchase 8 coil packs, the gaskets, and the spark plugs. i might make the intake manifold a separate project, see how well it runs with good plugs and coils. I bought this car from my grandparents and they bought it in 98 new and took pretty good care of it except for some high mileage maintenance. so far im about 2k invested in repairs on it and i have no problem going to 5k or so because this is my DD for a 60-mile per day commute. would rather fix up this car than deal with payments and full coverage insurance. so basically my vision for the car is to just replace the broken stuff with new and not really do any performance upgrades. thanks again for the input!
