loystock »
https://forums.nicoclub.com/loystock-u10145.html
Mon Jul 13, 2009 10:55 am
Just a reminder, the Knock Sensor will not turn on the SES light but will store a code in the ECU. Since the SES light is still ON, per your info, you still have a problem with your ignition system.
I'm assuming you broke the connector on the harness side of the Knock Sensor. If so, you have 3 choices - buy an Infiniti Terminal Repair Kit, P/N: 38751-95INF (expensive and may be an overkill); buy the harness from dealer or used car parts store; or pull out same harness from an Infiniti/Nissan car in a junk yard. There are at least two of them near you - Pick N Pull at 1065 Commercial St (off Berryessa Rd) in San Jose (Ph:(408) 452-1274) and Pick Your Parts at 595 Trade Zone Blvd, Milpitas (Ph: (408) 262-4500). You have to bring your own tools to get the required harness. Look for a 96-99 I30 or 95-99 Maxima and the harness should be an exact fit. The same knock sensor is used in other Infiniti/Nissan vehicles below so the connector may be the same but the harness length may be different.
1991-1998 NISSAN 200SX , SE, SE-R, LE L4 2.0L & 2.4L 1989-1996 NISSAN 300ZX V6 3.0L 1993-1999 NISSAN ALTIMA GLE, GXE, SE. XE L4 2.4L 1990-1993 NISSAN D21 PICKUP, SE V6 3.0L 1998-1999 NISSAN FRONTIER L4 2.4L 1992-1999 NISSAN MAXIMA GLE, GXE, SE V6 3.0L 1991-1993 NISSAN NX L4 2.0L 1992-1999 NISSAN PATHFINDER LE, SE, XE V6 3.0L & 3.3L 1994-1996 NISSAN PICKUP, KING CAB XE, SE V6 3.0L 1993-1998 NISSAN QUEST GXE, XE V6 3.0L 1991-1999 NISSAN SENTRA GXE, SE-R, LE, SE, XE, CLASSIC L4 1.6L & 2.0L 1990-2001 INFINITI J30 & Q45 ALL 1991-1996 INFINITI G20 ALL 1997-2000 INFINITI QX4 ALL
