loystock »
https://forums.nicoclub.com/loystock-u10145.html
Wed Nov 16, 2011 2:10 am
Both mechanics are correct, depending on what tranny service you want. If he will just do a drain-and-refill, then it's just the crush washer on the drain plug (same as oil drain plug washer) that needs to be replaced. If your car has over 80K miles and no history of tranny flush, then no decent shop will flush it due to liability issue. It will be safer to just do a multiple drain-and-refill.
In all the cars I have, I do a pan drop to clean the magnets and replace filter, if necessary, on the 3rd year. As always, make sure you have the correct fluid level before initiating a drain and add fluid matching the amount drained. A new gasket is required before installing the pan (and crush washer for the drain plug). Per Nissan/Infiniti, the pan bolts are one-time use but other owners, including me, have re-used them without any problem. You can apply Loctite as needed. After the pan drop, I do multiple drain and refill - run engine for @ 100 seconds and then immediately drain. Perform this least 3 times (including the pan drop drain). I used to repeat this every 2 years thereafter but found it unnecessary. So instead of a pan drop, now I just do multiple drain and refill every 2 years. In fact, all the fluids in the cars are changed every 2 years. All 5 cars have original engine, transmission, coils and injectors.
So from above, your other mechanics is also correct. I suggest you do a pan drop and you will be surprised how much gunk has accumulated on the pan and magnets. Your filter will probably be dirty and need replacement. Please note that the mounting bolts for the filter have different lengths and one of them actually has a nut.
Nissan Matic-D is the recommended ATF but Dexron III (obsolete) or the newer Dexron VI will do the job. If using Dexron III, better add a bottle of Lubegard (Red) ATF Protectant.
As for the Knock Sensor, resistance should be @ 550K ohm. It usually failed-open. I have done KS replacement in the 97 and 99 I30 and the latter is harder to replace.
