almost 115k milesTowncivilian wrote:How many miles do you have on your QX4? Was the service engine soon light illuminated or blinking? Have you changed the fuel filter within the past two years?
I should be able to get the plugs and filter fixed fairly quick. Hopefully that can at least get it without stuttering so I can get the car home w/o having it towed.Towncivilian wrote:Have you had the timing belt and spark plugs serviced around 105k miles? If not, I would get those serviced as well as the fuel filter and go from there.
