1991Hardbody »
https://forums.nicoclub.com/1991hardbody-u182264.html
Wed May 11, 2011 8:40 am
Ok. Here's what I could find for you, hope it helps get you started.
P0335 Crank Sensor. Located on transmission housing. Reads off the flywheel.
P0400 EGR. Typically means PCM is not detecting EGR flow when required. Look for any broken vacuum lines! May also be bad EGR!
P0443 Evap. Canister Purge Control valve. Check wiring going to evap canister. Test components on canister to ensure solenoids move!
I know I haven't gone into too much detail, but hopefully this will at least point you in the right direction. Don't know what your skill level is, but if you have a good manual and multimeter, you should be ok!
Good luck in your efforts!
