sanford7575 »
https://forums.nicoclub.com/sanford7575-u10575.html
Mon Feb 22, 2010 7:09 am
Please help! 1997 Nissan Maxima SE Automatic, 128K. My problem is that after sitting overnight, or all day after work, the car starts, but then dies immediately. It starts right back up and then dies immediately repeatedly, and then after the 3rd attempt and a little gas, it stays on and operates normally. No codes or CEL.It sounds like a fuel issue to me, but doesn't seem like a bad relay, fuel pump, pressure regulator, or injector. Any suggestions??? Fuel Filter? IAC?I used to have an old Volvo, and they have fuel pump check valves that actually preload gas into the cylander when you shut off the engine so that there is gas in there ready to go upon the next start. Is there anything comparable to that in these maximas? It seems as if the car is getting no gas immediately after initial start up, but then works normally after the 3rd start/stall.
Any and all help is greatly appreciated.
