MilkMan wrote:Carlos I feel your frustration. I had an EGR code last year on my 97. Turned out that the valve itself was working fine, just one of the passages was clogged. (The small pencil sized pipe that has a vacuum line attached) Not sure how many miles you have on yours, but after about 100,000 miles the top end is considerably looser, which means carbon build up is a matter of fact. Im pretty sure I didnt help things by using a combination of cheap gas, and beating on the truck. Im now using 89 Chevron, and babying her until properly warmed up. Just keep at it. It took me almost 2 weeks of fiddling with it to get the CEL to stay off. Like Reverend said, its a matter of time before before I gotta pull my intake, and give it a good cleaning. This site has some Invaluable DYI write-ups.
Frustrated? ... Me?!!!
Do you know that finally I'm a graduated mechanic? Yes, I did stop guessing and I think I have found what the problem was...it is a long story...everything started with my Jewish grandmother getting married with a German man from Berlin... just jocking...
Some months ago, the pulley for the steering wheel stop rotating (was jammed) and in the middle of the highway the belt started to burn itself because was still circulating with one pulley in motion only. The belt can't handle anymore and broke apart. I managed to return home with the steering wheel hard to move because no pump was moving the fluid inside this system. I removed the residuals of the belt and replaced the pulley. That was the end of the story.
Days later, the engine checl light started to come On and later going Off when I used to speed up. As you can see, there is not a single relationship between the incident with the steering wheel with the EGR system.
Well, I started to do what an amateur does to fix the problem, I cleaned up the valves, but I wasn't careful enough to avoid the cleaner fluid to wet the diapragms inside the valves, so I opted for their replacement. When I tried to check the Solenoid valve I broke one of its pipes and I had to replace it. Still, the light was coming On and Off sporadically. I replaced the little hoses between valves and from all the surrounding area of the EGR system. The long hoses going to the far away solenoid and the carbon canister did look ok, so I didn't touch them. I also followed the instructions of the manual to verify the electrical connections and replaced to wire terminals. Still the engine light was coming On sometimes.
Today, I really started to put marks on the connectors, in order to clean up the intake manifold...I pulled the air filter...
And I saw that the job was going to be big, so, I decided to replace all the hoses before doing such a big task "as a just in case measurement". When I was in the store trying to buy 15 feet of the hose, I changed my mind and I only bought a 6 foot long hose. I pulled the hose bettwen a tube down on the manifold, and that goes to the carbon canister, and I was surprised with what I found
Apparently, when the steering wheel belt got broken, in its way also destroyed the side of the little hose, but I can't see it because was at the botton side, and the location of the damage cannot be perceived at all but only by removing the hose.
I replaced the hose, and rised up the bench seat to set the ECM and check the history -the usual 32- later to erase such a record, and tested again, and it game me the perfect 55. I installed everything back in place and made the road test.
I traveled in a highway for a while at different speeds and the engine light didn't show up. I'll hope the problem has been fixed, because I really was thinking to use a sledge hammer to speed up the removal of the intake manifold....
