goody94q45 wrote:1.) About a month ago I cleaned the 4 tranny connectors on the underside, drained and refilled with 3 1/2 qts of Mobil 1 ATF, and poured in a bottle of Lube Guard Black (LG Red for regular ATF).
2.) I talked to a coworker/auto buff who thinks that the shift solenoids have been gummed up since purchase and even though I managed to clean up the 2-3 and 3-4 solenoids with fluid changes and Lucas ....
3.) The drive through Yosemite in 3rd gear cooked the fluid ....
1.) Let me quote TexasOil’s erudite post on this subject:
Lube Guard red vs. black
Red is synthetic sperm oil (can't kill whales anymore) and is used to smooth out the final engagement shock (lock-up.) It is a friction modified that lowers the coefficient of static friction relative to the dynamic friction. Dynamic is when the clutch faces are slipping past each other--static is when they are stationary.
Black Lube Guard increases static friction and dynamic friction coefficients, raising the locked-up torque handling capacity of the clutch unit (results in 'firmer' feeling shifts)
The Q45 TCU/ECU backs off on torque during the shift to give smooth shifts. For a given tranny condition/temp/oil condition, one can 'tune' the fluid characteristics somewhat. Factory settings are a compromise between smoothness, durability, and performance.
Ideally you would get a continuous flow of driveshaft torque under all throttle and speed conditions, with no noticeable jerk or sag. Hard to achieve in this world.
You want to be careful with harsh shifts--they stress the metal parts and clutch faces (and drive line parts) more than intended. This is not to say they will fail (right away), but incremental wear/damage is unavoidable with hard shifts.
Regarding Lube Guard. (No comment on Nissan D fluid since I am ignorant of the specific characteristics) I AM knowledgeable on DEXRON (all previous and present versions) and the 'type F' fluids.
Q45's through version III for certain were designed for the friction characteristics of DEXRON. This fluid had friction modifiers that shallow the slope of the torque vs slip curve as the clutches approach 'lock-up'. AND these fluids are suitable for those cars that ALLOW continuous slip of the 'lock-up' torque converter to smooth things out.
Some transmissions are designed for different fluids, ones that have either no drop in torque transfer as slip goes to zero, or even fluids that have HIGHER torque transmission ability as slip drops to zero. This characteristic is called HIGH STATIC FRICTION. Dexron fluids have HIGH DYNAMIC FRICTION.
If you put a 'high static' fluid in a transmission designed for 'high dynamic' fluid, you will significantly increase clutch lock-up shock--even to the point of shearing the metal driving lugs on the clutch plates. You may even feel a 'firmer shift', but that is easily confused and misnamed. You can also get a 'firmer [faster] shift with higher viscosity fluid or increased oil pressure in the transmission operating circuit. 'Firmer shift' and 'clutch lock-up shock' are different processes and not necessarily coincident. You can have 'soft shifts' caused by worn clutches, leaking clutch pack seals, low oil pressure, and STILL have 'lock-up shock.' You can have fast, firm shifts and still have smooth , no jerk clutch lock-up.
I recommend AGAINST adding Lube Guard BLACK to Q45 transmissions in an attempt to get 'firmer shifts'. All you are doing is increasing the momentary torque loading( lock-up shock) on the metal parts in the tranny and can brake some real expensive parts. This transmission IS NOT designed for harsh shifts and WILL break.
IF your Q45 tranny has slow, lazy shifts at moderate and more throttle openings, slips on shifting (engine speeds up), then either your throttle position switch is misadjusted, the transmission is worn and leaking internally, the oil filter is plugged, the fluid burned (worn-out), the clutch linings coated with varnish (from infrequent oil changes) or the valve body is malfunctioning for some reason.
Change the fluid. Add one pint of Berrymans Transmission cleaner and seal conditioner--run it easy for a week, re-drain and refill with DEXRON III --not synthetic--most DEXRON III fluids already have as much as 50% 'synthetic' base oil in them to meet the very low temperature viscosity requirements. What you are trying to do is clean off the clutches, clean out the valve body, and renew the friction modifier additive package. IF the shifts are not velvety smooth on lock-up, add one pint of LUBE GUARD RED. Do not confuse 'smooth lock-up' with 'firm shifts'. DO NOT ADD LUBE GUARD BLACK trying to get 'firm shifts'. To get 'firmer shifts' you will need to increase the transmission 'line pressure'. There are after-market spring/parts kits to do this. Use at your own risk. You DO NOT want to create harsh clutch lock-up under any condition--the metal parts will not survive.
2.) Maybe I am skeptical to the extreme, but I don't think Lucas (whose base is gum?) helped anything. I remember stories about used car salesmen putting sawdust in automatics so they would shift smoother which they did for a while then cratered a few weeks later. Kind of like saying butter is good for the arteries.
3.) I can't believe that hurt anything, especially if you have the B&M auxiliary ATF cooler installed, especially if running M1 ATF. Bets are off with Lucas in there. In fact, climbing in 3rd is better than in D with TC locked.
Early Q45 transmissions from LA were almost all cooked by the drive to Vegas at high speeds due to heat and inadequate early heat exchangers. The 1994 and later G50 dual heat exchangers and external ATF filter were marked improvements, but the additional auxiliary ATF cooler is a must in hill, mountains, high heat or high speed.
Modified by maxnix at 3:44 PM 4/29/2009
