Money ain't an issue in this case. I will be purchasing 8 brand new injectors, knock sensors, temp sensors, o-rings, and perhaps some cooling hoses. I had no issue removing this in 2 hours after removing the plenum form my last one back in 2009.
I got the memory down like that. As to the active suspension, I haven't tried it because the car was towed and then taken apart. I did see it function before purchasing since he had the car running for like 3mins.
Didn't think much or replies after I got the response I needed.
justjuiceit4: I figure that was the main reason it was different I wasn't 100% sure though so I tripped out and wanted to make sure.
OwnerCS: Yeah I got no clue where they all went. I did some research and a lot say they aren't really needed but some said it's to project the tip. I prefer to have the pintle caps and be safe though.
goody90q45: How you been man? Yeah I got no clue how to use this thing anymore. I did send you an email I think? Once I get this running after Christmas or before I will post about the Active Suspension. I missed my Q so much I finally got another haha. The car is just too amazing.
Q451990: Thanks for your response, I will try to clean the plugs since they are new but #3 is just BLACK!!!!
Any suggestions?
I also assume the main cause why all the injectors and plugs got wet was due to turning it over or trying, so I hope nothing happened with the motor. I do recall trying to crank it and hearing a big clunk, though it sounded like it wasn't getting enough power that's all, perhaps the battery was dead?
CROSS YOUR FINGERS NO HYDROLOCK!
