94Q45Beast »
https://forums.nicoclub.com/94q45beast-u244772.html
Mon Apr 20, 2015 9:23 am
I adjusted the throttle cable, started the car and it gave me the same symptoms except it idled at 1700 +/- 100 rpm instead of 2200+.
the next morning I started the car, it ran great, idled at 800 rpm, no bucking or jerking when put in gear the idle (letting the car roll) it was around 700 rpm and drove perfectly (except I need to change the 6 year old LSD oil), but when I came home and shifted into "park" to turn the car off, it idled higher around 1200rpm, the same day in the evening I started the car to go run some errands and it was back to the way it was when I first adjusted the throttle cable (idle 1500-2000 rpm), gear idle(when put in gear) increased to 1500 rpm and shifting into second on its own, bucking and jerking when put in gear.)
