3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Mon Feb 16, 2015 3:40 pm
Not sure there is a specific concern? Undo the tie rod ends (either at the knuckle, or count turns if you want to keep some semblance of toe when you reassemble), undo the steering shaft (mark it), maybe an electrical connector, undo the hydraulic lines, undo the 4 bolts that hold the rack in (2x2 u-shaped clamps)......
would that be a "travelin javelin" (390)?
