93 D21 code scanner recommendations
oleman
Car: 1993 Nissan D21
Anyone have a recommendation for a reasonably priced code scanner for a 93 D21.
I want one that reads out in digits.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I use an Ultragauge from http://www.ultra-gauge.com/ultragauge/index.htm. It suction cups to you window and gives you realtime data reading along with diagnostic codes and cose clearing. My Versa has only a speedometer, with the Ultragauge I am able to read most of the sensors that the ECM is listening to, all day long too as I drive along. It's the best deal I have found for general car owner scan gear.
o0Syn
Car: 92 Nissan 240SX Convertible
You use this in your 95/91 and it works Rev? Cause from what I can see its only OBDII compliant
Rev_D21
Yikes! You are right! What was I thinking?!?
