92 Q45 no start
badbadlee
Car: 92 Q45
help!!!! i have a 92 q45 with a no start prob!!! it has 50 psi fuel pressure spark on all 8 coils has pulse on injectors and has 140 psi of compression i know it has 2 cam sensors and 1 crank sensor but i dont know if they are the problem i am at a loss i am used to working on american cars with less sensors. i live in las vegas if the heat has any thing to do with the cause of my problem help please leroy
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Please give us an accurate description of what occurs when you turn the key. Not flooded?
A brief maintenance history and note on its condition may help with a car we cannot touch nor hear.
Modified by maxnix at 11:19 AM 6/16/2005
DAEDALUS
Car: 1990 Infiniti Q45
There's only a single "crank angle sensor" but it's located on the left head exhaust cam. The other 2 cam "sensors" are variable timing solenoids. If you haven't touched the CAS, and if you're getting spark on the plugs, then the timing should be OK. Ditto Maxnix: You're sure it's not flooded? How long since it first refused to start?
badbadlee
Car: 92 Q45
i thought that so i checked out plugs all dry thats not a problem. which sensor decides which plug and injector fires first ?please help leroy
badbadlee
Car: 92 Q45
new plugs ,one new module 140xxx miles and it just broke down about a month ago ? any thing else needed info needed let me know
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
badbadlee wrote:it has 50 psi fuel pressure
After the fuel filter? More data, please.
badbadlee
Car: 92 Q45
yes i taped into line at rail up frt on top ?
badbadlee
Car: 92 Q45
yes up top right at the rail leroy
DAEDALUS
Have you tried cranking it with the gas pedal mashed to the floor? This will shut of the fuel injectors to clear any flooding.
badbadlee
Car: 92 Q45
yes it sounds like its trying to hit on a couple of cyls but never actually starts
badbadlee
Car: 92 Q45
ques? does parts from a 94 q45 interchange with a 92 q45?
Qgrappler
My 94 Q will become unwilling to start if you start and move it a short distance and let it sit. A dealer told me they have the same problems arising from moving cars into the garage and back out again after servicing. .
The solution is to have a strong battery and to hold the pedal all the way to the floor, and have the guts to let it keep cranking. When this "lock-up" occurs, or whatever you want to call it, it takes a long attempt to start it before it kicks in. I would say, in some cases maybe 15 seconds or so, which seems like an eternity.
badbadlee
Car: 92 Q45
i have tryed that for longer than 15 seconds prob 30! i think i have a set of bad injectors the 2 i can get to one is leaking and ohm at 14 and the other one is at 26 ohms and i know thats bad also the wiring harness dont look the best is there a replacement ends or injector harness?
badbadlee
Car: 92 Q45
does any one know how ignition modules work ? do the same side cyls fire off same side module or are they split???? i have a 94 q45 also i am working on and the exhaust temps are way different one side is at around 300 deg and the other on is at 130-150 is this poss a bad module ??? how do i ck the modules????
DAEDALUS
There's an ignitor on each head that is controlled by the ECU to break current to the COPs. If you're getting spark I don't see how the ignitors can be the problem, but check to make sure all the harnesses under the hood are connected. Probably not easy to check the ignitors without a scope or at least an inductive ammeter.
