bluemaruder001 »
https://forums.nicoclub.com/bluemaruder001-u238866.html
Thu Jul 17, 2014 6:53 am
Hello all!
I have been fighting an issue with my 92 Q45 Base. I had an issue with the second cylinder on the drivers side. It appeared that the injector was leaking fuel into the cylinder and was hydro locking the engine. I actually broke the starter nosecone when it happened. (wasn't running luckily). I put new injectors in about a year ago, OEM ones. I pulled the problem one out, the O rings looked ok except they both appeared to be very loose fitting. I also pulled all plugs out to make sure I wasn't dumping fuel into any other cylinders, which I was not. I replaced the O rings on the one injector with a set off my old injectors, re installed and was still dumping fuel into that cylinder. I ordered new O rings for all 8 and replaced them. ( was thinking the ethanol could be to blame as the car has sat a lot the past 3 years. I now am not dumping fuel into the cylinder but it is running rough and dies when warmed up. I know I probably have a bunch of fuel in the exhaust system that needs to be worked out. I have changed my oil and filter 2 times due to fuel getting into the oil. when running and warmed up it is emitting white smoke and I have a strong fuel smell and I am dripping fuel out of every opening in the exhaust system on the drivers side. Fuel pump and MAF have been replaced. It was running fine until all this started. I have also done compression check and that appears to be good on all cylinders. I have had the timing chain guides done, trans re built and new drive shaft so I really don't want to give up on her.
Any input would be greatly appreciated!
Thanks.
