rrack »
https://forums.nicoclub.com/rrack-u1705.html
Wed Aug 16, 2006 5:50 pm
K...about two years ago I completely reworked the A/C system because of some leaks...new drier o-rings, compressor, expansion valve, etc...everything has been fine until yesterday...Well, except for the darn cooling fan up front. That darn thing never really worked right. I sorta think it's the pressure switch for it that needs replaceing. This may be the time to take care of that too.
Anyway, I noticed that it just hasn't been cooling all that great when at idle...could have something to do with this Texas heat and not enough air moving up front with that fan not working. Anyway, I grabbed the gauges and a dusty can of R-12 from the vault. I couldn't get the gauges to work right...someone borrowed the fittings. I went ahead and used a small straight line and used the eye on the drier. It slowly took the entire can and the eye looked good. Appeared to be cooling great. Well, half way home today the compressor stopped pumping. Just hot air blowing. Once I got home I started tinkering and jumped the pressure switch on the drier and it will spin the compressor and cool fine. I'm not sure how this particular switch works. Will it shut down if over charged? I'm thinking it may just be clogged up? From what I'm seeing from the old drier, I can't simply swap out switches without evacuating the system of the R-12 gold. What to do? For the moment, I've got the pressure switch jumped for the short ride to and from work hoping I don't blow something up.
Any tips would be great.
Thanks much.Robert
