Minnyman »
https://forums.nicoclub.com/minnyman-u45035.html
Wed Aug 09, 2006 3:32 pm
Hello all! Im new to this forum, but it seems the best and most informative one i've seen. Tried the google nissan group thing but no one would answer me
On to my troubles.
The timing guide broke on my truck, Im not much of a mechanic so i let it sit for a little while (7 months... ). Finally tried to fix it cause i'm a poor college student.
Everything seemed fine lined it all up, silver links on chain to dots on sprockets, TDC on both shafts etc. Started it and it runs but when i try to go it stalls out.
Now the insane part, Ive replaced dist/cap/plugs/fuel pressure reg/oil & fuel filter/vacuum lines and probably more i cant remember...as i've said im not much of a mechanic lol. Still runs the same.
The first time i did not replace the timing chain or sprockets and thought maybe i lined them up wrong so...I did it again and put in a new chain and sprockets. still runs the same.
For some reason I was under the assumption that you could not adjust the timing and that it was controlled by the ECU thing under the seat. I think this is my problem as after reading here i see all kinds of threads about adjusting the timing via a gun and turning the distrubutor.
My question now is that what is wrong and if so what is the degrees for this vehicle because my panel on the hood is long gone?
Lastly if that is the problem i may cry a little due to doing all the extra work.
Thanks-Minnyman
