The car has been running great since fixing codes (12 MAF - 32 EGR - 34 Knock sensors - 53 Exhaust Gas Sensor)
Fixing the vacuum lines and pulling a ball bearing out of the EGR tube fixed all of them.
SO Today-
I have never set the timing on this car so figured I should check it.
I followed the instructions at
http://www.q45.org/checktiming.html - went with the technique in "B".
The timing was 25º BTDC actually it was even a bit higher. Like I said this car has been running great at all speeds.
I set it to 15º (4th notch from the left) - Idle at 650 took it out and all though it idled and ran smoothly under gentle acceleration it had NO power under medium to heavy acceleration...like NO power flooring it.
SO I set the timing to 20º and it was much better...
This thread reports something similar but it is never resolved
post4571722.html?hilit=q45%20timing%20q ... s#p4571722
This makes no sense to me...any ideas as to what is going on?
..Throttle Position Sensor?
Is it ok to just time it to what it runs best under and forget it?
...is it possible that the cars electronics have compensated for past errors and is now set to run at 25 BTDC?
If so, is there any way to reset it all to a default running configuration?
Tim
